I don't know. I want to knowledge about this phone.
How to fixed hard reset Samsung Galaxy A 14
Es esta una buena pregunta?
Warning: The factory reset action will erase all data on the smartphone. Make sure you have backed up your data so that important data is not deleted.
Attention: Before resetting, you should log out or delete the Google account logged in on your cellphone, by going to the Settings menu > Accounts > log out of the Gmail account. This is to avoid cases where your cellphone is locked by FRP because you forgot your Google account.
How to Reset Samsung A14 5G in the Settings Menu
The first step is to enter the settings menu or "Settings".
Next, scroll down and look for the "General management" menu.
Then scroll down again and select the "Reset" menu.
Then select the "Factory data reset" menu.
Then scroll to the bottom and select the "Reset" button.
After that, enter the screen lock pattern, password or PIN (if any).
Finally, click the "Delete all" button.
After all the steps above have been successfully carried out, the Samsung A14 5G cellphone will start to reset and after that the cellphone will restart automatically.
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 19
Todo El Tiempo: 63
