Saltar al contenido principal
Popular laptop sold by HP. While it comes in many configurations, all models of this laptop have the same basic form factor. The numbers after G60 indicate the factory specifications of the laptop and who sold it.
Preguntas 40 Ver todo
Pregunta Cerrada
My screen goes out and comes back on perdically
The screen stops working perdically for no reason then later will come back on. It will turn blue with white and black lines. When I attach an external monitor everything works fine, but it is not convenient to have an external monitor hooked up all the time. The monitor will perdically start working normally again and I can't seem to figure out what is making it stop and start working again. Does the LCD screen need replaced.
Es esta una buena pregunta?
Puntuación 0
1 comentario
Are the lines horizontal or vertical? Try moving the screen towards and away from the keyboard, during the different phases (blank, with lines and working normal) and let us know if it changes the image on the LCD, if so how.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
If the screen does work from time to time, it sounds like a bad display cable or screen
first take the computer apart and check the connection from the display assembly and make sure it is in, this will help sometimes, but not likely, tough worth a try
Test it for a few days after you do that to be sure
if it still does this, try replacing the display cable, although this is for the LCD screen swap, it will show you how to remove the display cable
http://www.insidemylaptop.com/remove-rep...
if that does not work, it is probably the display at this point
follow the screen guide i linked, it will cover the LCD and display cable
Fue útil esta respuesta?
Puntuación 1
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,670
