Saltar al contenido principal
Unibody de aluminio de 13", procesador Core 2 Duo de 2.0 o 2.4 GHz.
Preguntas 574 Ver todo
Dust under the screen.
My screen i pretty dirty under the glass and I would like to clean the dust from there.
Can I remove the glass from the display without removing the whole display first?
And do I need to replace the adhesive tape after cleaning.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
My personal advise is try to live with the dust or take it to an Apple Certified Provider to do the job. 90%+ of the people that attempt to remove the glass break it. If you do the job yourself, make sure you have located a place to acquire the glass and adhesive in a timely manner, as you may be without use of your laptop until they arrive.
I am certain the glass can be removed without removing the display assembly, but it is not feasible to attempt it. You increase your risk of breaking the glass and/or damaging other things. You are best off replacing the adhesive when you install the glass for it to seal properly and keep dust out.
Fue útil esta respuesta?
Puntuación 2
See this guide.
Puntuación 0
1 comentario:
The video is not available
- de
Añadir tu respuesta
munkero estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 3,925
