Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Repair and additional information for the GE Profile Refrigerator PFSS9PKY—a bottom freezer style refrigerator with an ice dispenser and dual access via a drawer and door, released in 2009. This page covers information for model numbers matching the pattern PFSS9PKY***.
Freezer not cooling down, Temp on front display shows -2,
The front display shows Freezer -2, Fridge 34. The fridge is at 34, checked with thermometer.
The Freezer is the same temp as the Fridge.
Would this be a sensor, since its reading the wrong temp?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios:
This is a PFSS9PKY Model
- de
@dougriley I would start by checking the thermistor for the freezer. Try holding it tightly in your hand and seeing if the temperature changes on the screen. Alternatively, if you have a multimeter, you could hook the thermistor up to a multimeter and put the multimeter on ohms mode. When you hold the thermistor tightly with your hand, you should see the ohms reading on the multimeter go up or down.
- de
Agregar un comentario
1 Respuesta
Hi @dougriley
Here's how to find out if any error codes are stored in the refrigerator that may show what is not functioning correctly.
Enter the diagnostic mode > service diagnostics > self diagnostic test
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Doug Riley estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 23
Todo El Tiempo: 226
