What can I do if my phone get wet?
unfortunately i didn't close my water bottle, so some water pervades into the phone. The indicator is now rose. What should i do?
Es esta una buena pregunta?
Victoria, the first thing I would do is to remove your battery. After that you do want to disassemble your phone and clean it with some high grade isopropyl alcohol. That will displace all the water that may have accumulate on the inside of your phone. If you do not remove that, you are standing a chance of getting corrosion on your boards. That will lead to failure later on. Once you cleaned it, replace your battery and see what, if any, damage you may have. Follow the link to the Electronics Water Damage pointed out by Derek Halman. If you are unsure how to disassemble your phone, you can download the service manual from here.It will show you each step of the disassembly. Hope this helps, good luck.
Fue útil esta respuesta?
First: DO NOT apply power until it is completely free of liquid or moisture.
Second: Try using a [producto vinculado inexistente o deshabilitado: IF145-163] to remove all the moisture from the device.
If this does not fix your phone, you can learn more by visiting:
my phone get wet and it can not power on
My Nokia phone is not working right and I droopt it in water how can I fix my phone
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 4,641
3 comentarios
will i left my phone in my bagpack and i was walking to school and it was raining so it got wet.
- de Josie1
Actually my nokia 2 mobile fell in water im going to nokia servicing center but he can't resoved that problem he told your mobile is not worked any other solution to work my mobile
- de SUNNY amile
My phone get wet in rainy season I want to change this phone 3months old
- de Anmol uniyal
