Bonsenkitchen Popcorn Maker Model PM8901 Won't heat, blow air
I recently changed my popcorn type to mushroom type. I think this may have caused it to overheat more than typical. I suspect this type might need more heat to pop.
While popping, the machine stopped working (It turns off if overheating.) It stopped working and now will not work when plugged in.
It has an on/off switch which will light when on, so I know it's not a cord issue.
Is this repairable? How do I find out?
I became impatient, and tried to open it. Hiding under the rubber feet are screws with y shaped slots. I have never seen this type, are they common? Also there are two Phillips head screws, these are deeply recessed, I am not sure I can get to them with the screwdrivers I own.
Es esta una buena pregunta?
