How to repair door window. It's hardly go upward
Driver's side door window is not working properly
Es esta una buena pregunta?
@naina67714 could be a bad roller in the window regulator or a failing power window motor. Here is the part of the SM that deals with the power windows Swift Power Windows. Check the window regulator and see if that moves properly
Fue útil esta respuesta?
ok dont laugh but if its really slow to go up but goes down normal speed youll need a can of wd 40 and what you do is while window is up you coat the whole window with wd40 spray outside ,protect the paint best you can with a towel or?but spray it like you were washing the window fully coat it and then do inside as well ,let it stand for a couple minutes then roll it down ,after that wd 40 both the tracks the window slides in and anything.else attached to glass ,arms cables ect then try running it up and down to see if it helped and wipe off any overspray on out/ inside with a little gentle dish soap or car wash soap (prefered) and wet rag
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 63
Todo El Tiempo: 540
2 comentarios
@naina67714 are those power windows? It goes up, just very slowly? what have you checked?
- de oldturkey03
Driver side window is closing hardly
- de Mohammed Sameer
