Saltar al contenido principal
La revisión de 2016 de Apple a su línea de computadoras portátiles dirigida a usuarios profesionales. Cuenta con una pantalla Retina de 15 pulgadas, 2880 por 1800, Intel Core i7 de cuatro núcleos, opciones de almacenamiento de 256 GB / 512 GB / 1 TB / 2TB, 16 GB de RAM y un teclado equipado con una barra táctil. Lanzado en noviembre de 2016. Características del modelo A1707.
Preguntas 266 Ver todo
MacBook Pro won’t turn on after battery replacement
I just replaced the battery in my MacBook Pro 15” 2016 (using the iFixit replacement battery, tools, and guide) but now it won’t turn on at all. After the replacement, I plugged it in to charge as is instructed. A battery icon popped up on the screen, indicating that it was 76% charged. I then pressed the power button, the screen turned on for a split second and then shut off. Now zero signs of life no matter what I do.
I’ve tried all the recommended fixes that I can find (SMC reset, disconnecting and reconnecting the battery, etc.), and there are no visible signs of damage anywhere. At this point I’m worried that the logic board may have somehow been short circuited, but I’m not sure how that would’ve happened since I was extremely careful with my tools and there no signs of a short while I was working. Unless I scraped the logic board with the bottom case as I was putting it back on?
So I guess my questions are:
Does anyone have any idea what my be causing the computer to be dead?
Is it possible that the logic board was short circuited? What could’ve caused that?
Could this have to do with a faulty battery?
Any ideas for how to get it booted up again?
Thanks in advance for any input!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Have you tried running the machine without the battery connected? That way you can rule out the new battery as a potential cause.
Otherwise it's difficult to know. With battery installation, I would retrace your steps. Make sure all your cables are seated soundly. See if you get power if you disconnect other components (trackpad, touchbar, etc....)
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Miranda Mertes estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 17
Todo El Tiempo: 132
