Left Joy-Con won't stay attached, even after replacing latch
A month ago ish, i dropped my switch such that the right joy con's buckle latch broke and the joy con went flying to the middle of the room. I ordered the metal replacement latches from iFixit, and due to EU complications they arrived yesterday. When I was going to replace them, i noticed the left joy con felt loose too. After replacing the latches, my right joy con is very snug and feels better than when it was new, but now my left joy con still doesn't fit properly, it's even worse than before.
My left joy con, with a newly replaced latch (which was never broken on that joy con), fits worse than the right joy con after i dropped my switch and broke its latch. I have not over-tightened the bracket above the latch (which would explain it being stuck in the open position), and i do have the spring in its proper place (which again, would explain why it doesn't lock). I also noticed the latches are asymmetrical, and i made sure to align them with the correct joy con based on how my old ones looked.
Through various testing by tightening/loosening screws and removing parts, I've figured that the problem is the release button pushing down on the latch, even in its fully depressed position, such that the latch is permanently in its "open" position. Nothing is forcing the release button down, and it is installed with the tab in the correct orientation. When I reassemble the joy con without the release button at all, then it attaches to my switch perfectly just as snug as my right joy con (and i can stick my screwdriver in or something to release the lock).
I also figured out that if i attach the back panel to the rail with a loose screw on purpose (so as to not push the release button into the latch already), and don't attach it at all to the rest of the joy con, then the rail locks in place, but as soon as I press the back panel down properly, it's as if i pressed the release button and the joy con comes off easily.
I can't figure out how to solve this other than removing the release button, which is an unacceptable solution to me.
Es esta una buena pregunta?
