How do I fix my touch screen?
My touch screen just stopped working. It doesn't sense me touching it with my finger. If i press hard it'll barely sense it. I can't even unlock my phone!
Es esta una buena pregunta?
Don, try a hard reset by following the steps from here first"
1. Turn the power off. If your HTC Aria is frozen, pull the battery out and reinsert it
2. Hold the Volume Down button
3. Hold the Power button until the display turns on
4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Press and release the Power button to select
7. Confirm: Volume Up for YES and Volume Down for NO"
This will delete all the data from the phone, but not from the memory card.
If that does not help, you might be due for a digitizer replacement. The video instructions are available here and you can get the digitizer from places like this. Hope this helps, good luck.
Fue útil esta respuesta?
I have a HTC Legend. I tried your solution, I didn't know about the hidden menu. Mine didn't start after clearing storage. So I accessed the Fastbook menu and there I tried the second or the third submenu, I don't remember accurately. Thanx for the help!
memoriesfromthefuture, you are welcome. Glad I could help out, best of luck to you.
Just had my little htc aria unlocked at http://www.attphoneunlockingshop.us/ Thanks !!!. this is the only site i use to unlock lumias.
Go to this link and place the order: http://www.attphoneunlockingshop.us/prod...
Just had my little HTC Aria unlocked at http://www.attphoneunlockingshop.us/ Thanks !!!. this is the only site i use to unlock HTC Aria
Go to this link and place the order: https://www.youtube.com/watch?v=JsbjkX8p...
contact to nearest cell phone repair store to change lcd panel. if you believe it is OS issue so you can contact to http://attunlockcodes.com team for help.
thanks
Network unlock codes
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 44,657
2 comentarios
guys i have a huawei ascend and my heat sensor doesnt work please help how do i fix it
- de stephanie
Guy good mor/after/eve please help me my right middle screen is not functioning help me please#NEEDHELP
- de ermutuc
