Saltar al contenido principal
En 1999, el RL recibió un lifting frontal y trasero que incluyó la adición de nuevos y más elegantes faros de Xenón. La diferencia, aunque aparentemente sutil, le dio al coche un aspecto totalmente nuevo. La suspensión y el chasis se endurecieron. El Acura RL volvió a doblarse y las ventas aumentaron.
Can't open driver's door from either side
I was attempting to replace the driver's outside door handle (snapped clean off, already have the replacement) and had successfully removed the inner panel + window track from inside the door. While I was trying to figure out how to remove the connector attached to the plastic that moves when you pull the outer handle, my door closed and latched, and is now stuck. I had moved a part of the mechanism inside out of place in attempting to clear a path to the handle's screws, and the door will not open from the inside now as the panel is gone (pulling on the cable left behind makes a rather sad clunk but has no effect on the latch). Any way I can get the door open without drilling into the latch (which is the only answer I've found so far)?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@noaharagon I am sure that by now you have it opened. I would have gone ahead and suggested that you just follow the SM and disconnect the 7P connector from the keyless receiver unit. Then shorten the Green wire on this connector to ground. That is what will unlock all doors. Once unlocked you can most likely unlatch it, by moving the tab where the handle cable terminates, downward.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Noah Aragon estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 189
