Air bag light is on
How do I fix air bag light
Es esta una buena pregunta?
Hi Marlene,
Unfortunately the air bag light doesn't really help you figure out what is wrong. There are impact sensors to detect a crash, connections to the airbags themselves and frequently seat and seat belt sensors, any of which can fail and turn that light on.
However, standard OBD-II scanners won't give you information about airbag systems. It takes a Volkswagen-specific scanner called VCDS, or VAG-COM Diagnostic System, to look at the airbag system and get the fault information. If you can find someone with a VCDS scanner they'll be able to read out the errors; otherwise you may have to take it to a shop for a diagnosis.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 12
