Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Intel Core i5 de doble núcleo a 1,8 GHz (Turbo Boost de hasta 2,8 GHz) con 3 MB de caché L3 compartida
Replacement keyboard from MacBook Air A1369
I was wondering my mid-2012 MacBook Air A1466 keyboard does work and I was wondering if I can fix it with a keyboard for a MacBook Air A1369? Just wondering if two different model are interchangeable for the keyboard to fit.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
There are a few different issues you face. If the system a North American or a European system? And if European you have a few possible key caps with different language symbols.
Ok so let’s assume you have a North American system then you need the proper keyboard for your system as each series have different setups. Here’s the correct part MacBook Air 13" (Mid 2011-Early 2015) Keyboard. Sadly the older late 2010 keyboard won’t work here.
Its a fair amount work as you need to strip the system down quite far. So be prepared!
Imagen de Replace a damaged, dirty, corroded, or malfunctioning keyboard compatible with a model A1369 13" MacBook Air from mid 2011 or a model A1466 13" MacBook Air from mid 2012 to Early 2015.
Producto
$29.99
Fue útil esta respuesta?
Puntuación 1
6 comentarios:
It’s an American keyboard that is a 13” A1369 keyboard. So that will work then?
- de
@jordanchapman - Not if it’s a 2010 model
- de
So if it was a 2011 model then it will work?
- de
@jordanchapman - I don’t remember if the 2011 models used screws. I think this was the first series to use rivets. So if it has the rivets then you end up destroying the keyboard taking it out.
I would check things before going to far.
- de
If everything seems right then it’s alright to install it then?
- de
Mostrar 1 comentario más
Añadir tu respuesta
Jordan Chapman estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 270
