Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
28 Inch Top-Load Washer with 4.8 cu. ft. Capacity, 13 Wash Cycles, 4 Temperature Settings, PowerWash System SmoothClose Glass Lid
Drain pump continuously runs and runs
Drain pump wouldn't stop running no matter what I did I took apart the washer and found a washcloth clogged in the drain filter. Removed it along with any other debris and cleaned everything down. Check for clogs on all the hoses and elbows. Put everything back together and the drain pump continues to run no matter what I do. I don't know how to determine if it is the pump itself that needs to be replaced, the control board , the water level sensor or something else entirely. Any advice or suggestions would be greatly appreciated. I am stuck.
I went through Maytag diagnostics it runs to C1 - fills the washer with water and then stops completely.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @anthonyfab28396
Here's the tech sheet for your washer
On p.1 it shows the causes for a C1 error code.Since it is filling OK check that the water temp is OK (install manual shows the hot water supply needs to be120F) and also that the basket has lifted.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
I changed the model I had. This is an issue with my washer. Maytag MVWB880BW Bravos XL
Manual: https://www.manua.ls/maytag/mvwb880bw-br...
- de
@lilmink777
I've edited my answer above to link the correct tech sheet for your washer and what to check to find the cause of a C1 error code.
- de
Añadir tu respuesta
Anthony Fabiano estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 33
Todo El Tiempo: 1,170
