I Cannot charge my iPhone
i cannot charge my iphone though it was being plugged, i tried my friend's charger too, thinking that my charger is a problem, but still cannot
Es esta una buena pregunta?
Your problem could be one of two things, or a combination of both.
First inspect charge port on the bottom of the phone for signs of bent or damage. If all looks OK then clean the pins with Isopropyl Alcohol and a cotton ear bud. If it leaves any cotton behind then remove gently with a set of tweezers.
Second your battery may be totally dead. You can purchase a replacement from iFixit. Link below.
If you need instructions on how to replace it, then follow guide located here.
Reemplazo de batería de iPhone 4
Good Luck.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 12,334
1 comentario
i change battry also same problem, when i plug the charger only singe of apple long time plug on the charge many time also but i can't solve this problem
- de krishnashrestha44
