Saltar al contenido principal
La revisión de 2016 de Apple a su línea de computadoras portátiles dirigida a usuarios profesionales. Cuenta con una pantalla Retina de 15 pulgadas, 2880 por 1800, Intel Core i7 de cuatro núcleos, opciones de almacenamiento de 256 GB / 512 GB / 1 TB / 2TB, 16 GB de RAM y un teclado equipado con una barra táctil. Lanzado en noviembre de 2016. Características del modelo A1707.
Preguntas 259 Ver todo
Why is my screen displaying a black screen and question mark sign?
Why is my MacBook Pro showing black screen with a question mark sign in the middle?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
4 Respuestas
This usually indicates that it either doesn't see it's internal drive, or doesn't have one installed.
However if it doesn't recognize a present drive, repair is going to be extremely difficult because the ssd is soldered onto the logic board.
Try starting up into recovery by pressing the power button and holding Option-Command-R until a globe appears.
This should allow you to get access to some utilities to check your drive.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thanks for your comment @maxmc. I’ve but it can find the drive
- de
Respuesta Más Útil
@nmjz5vizxwsgwzm - Time to visit an independent Mac repair shop or visit an Apple Store.
Your system needs deeper repairs.
Puntuación 1
Well you can try the following methods to fix the issue you are facing:
  1. Press and hold the power button on your Mac for up to 10 seconds, until your Mac turns off.
  2. Use Disk Utility to repair your startup disk.
  3. If Disk Utility found no errors or repaired all errors, reinstall macOS.
Puntuación 0
1 comentario:
Thanks for your help @gtip. I have tried this process but it can’t find the disk where I want to install the macOS.
- de
Try this. Shut down your Mac.
Press the start button and IMMEDIATELY press the following 4 keys until you see a startup screen. (You may want to practice your finger positions before you begin because this can be tricky and you have to move fast.)
OPTION + COMMAND + SHIFT + R
You must hold all 4 keys down until the startup screen appears. If a finger slips off you'll need to start over.
You should be presented with an option to restore over the internet. Select your internal drive (if it's shown) and follow the onscreen prompts to reinstall the version of MacOS that came with your computer. You will need a network connection for this to work.
Puntuación 0
Añadir tu respuesta
kome75y2k estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 50
