Why does my washer leak during fill
I changed out the water fill valve. All connections are tight no leaking. Now my washer leaks at fill what could cause that?
Es esta una buena pregunta?
Puntuación
0
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 14
Todo El Tiempo: 51
@annsanders can you verify for us that your washer is a MVWB765FW? Also, do you know where it leaks from, like the bottom, or the back or other places. Since you replaced the water inlet valves already, I would suggest to look somewhere near the drain pump.
- de oldturkey03
