Saltar al contenido principal
Una SSD, o unidad de estado sólido, es un tipo de dispositivo de almacenamiento que utiliza una memoria flash basada en NAND para almacenar datos.
Preguntas 20 Ver todo
Can't access OWC disk over PCIe adapter
Hi guys,
I have issue with OWC SSDAD2MB05 480GB. I am trying to access this drive from my MP3.1 over PCIe adapter (other drives working perfectly).
But if I connect this drive after start it's taking longer before I can see icon on the desktop and I can't get access over DIsk Utility - just stuck on "loading disks" screen. Over terminal I can see that there is GUID_partition_scheme disk1, EFI disk1s1, Apple_APFS disk1s2 but I can't delete partitions or rename etc...
I also tried USB installer but it's again stuck on Disk identification ...
Do you think that this is an issue with disk ? It was taken from broken MBP - motherboard fails - or it's have something to do with APFS partition ?
Thank you for any advice/ideas
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
The drive is running APFS which only a Mac running a newer version of MacOS can access.
Your config won’t work as a MacPro 3.1 highest supported OS is OS-X is El Capitan (10.11.6) which only supports HFS+ volumes. You need to be running Mojave or newer.
Giving your testing the OWC SSD won’t play in the PCIe adapter you have. Sorry😩
Fue útil esta respuesta?
Puntuación 0
14 comentarios:
Sorry, forget to write that -There was Big Sur on MBP and I am running Monterey OCLP on MP 3.1
- de
@roboscrap - where did this drive come from? This could be encrypted then.
- de
@danj it’s from broken MBP - how can I find if it’s encrypted? And if it is can I do anything with that ? I just need format this drive - I am not interesting about data on it.
- de
@danj added full list of diskutil from terminal, that all what I can get from Drive no other access :( not even in Windows OS
- de
@roboscrap you need to delete the partitions, then repartition it as a flat drive I would just setup HFS+ if this will be a data drive.
- de
Mostrar 9 comentarios más
Añadir tu respuesta
Rob estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 92
