Saltar al contenido principal
La versión mejorada de Nintendo de Nintendo 3DS. Cuenta con pantallas más grandes, mayor duración de la batería, mejor densidad de píxeles y un mejor diseño.
Preguntas 409 Ver todo
3DS not booting after updating?
So basically i have a 3ds xl that I bought online that had pirated games on it, I played a while on it, and then for some stupid reason wanted to update it...and after I did that, it stopped working, It flashes blue ones and then nothing, doesn't even try to open. Hope I didn't brick it, It was 4-5 years ago, so I don't know what version of luma it had on it.
Most things online say that it is a booting problem, so I bought a new microSD (someone took the old one that was originally there), samsung 64GB and tried to install luma on it with tutorials and such, but it really doesn't work and I can't seem to find a solution? But the card is brand new, doesn't have any folders on it, hopefully it doesn't need the "nintendo3ds" folder for it to start.
I read somewhere that 3ds can't read 64gb cards, could that be the problem? Or is that kind of BS.
I will try to install luma again from zero later, just to check if I really did everything right.
Hopefully there is a solution for this, I'm new to this and this is my first 3ds and I was very excited to have bought it. I just wanna play animal crossing that I bought :( Sorry if my questions sound stupid to someone! If anyone is willing to give some tips thank you!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
DO NOT try to install luma from zero. B9S is stored on internal memory, not the sd card. Trying to restart from zero will probably make your problem worse
- de
Agregar un comentario
1 Respuesta
Let's start with the sd. You can go up to 128GB with no problems, but cards above 32GB need to be formatted to FAT32 before you can use them (preferably with GUIformat if you're on windows). Once that's done, just copy your files over and use it like normal.
The booting problem is pretty simple. Download the latest Luma3DS, copy boot.firm and boot.3dsx from the zip to the root of your sd, then pop the sd back in and try booting again
Fue útil esta respuesta?
Puntuación 0
8 comentarios:
for me it still doesnt work what can i do?
- de
@jopiejo What exactly is the problem, and what have you tried already?
- de
@darthmango hi! i have the exact problem and was wondering if you could help me? i did what u asked in the comment above but it still wont turn on :(
- de
@darthmango hi! i have the exact same problem and was wondering if you could help me? I did everything you asked in the comment above but it still wont boot up :(
- de
@darthmango i have the exact same problem and was wondering if you could help me? I did everything you asked but it still wont boot up
- de
Mostrar 3 comentarios más
Añadir tu respuesta
Golden Bug estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 22
Todo El Tiempo: 406
