Why does my mama's 2005 Kia Optima act like it's not getting gas?
My husband just did a oil change, and oil treatment on my mama's 2005 Kia Optima, and now when we start the car it idles very roughly, and when we put it in gear it almost dies. What could be causing this?
Es esta una buena pregunta?
13 comentarios
I forgot to mention that a mechanic told us to check the catalytic converter. So my husband took the exhaust loose from the manifold, and it still runs like crap. Any ideas?
- de Amy Geeter
Did it run okay before the oil change?
- de oldturkey03
Not really. The idle was off a little, it has a vibration when idling or in gear, and other minor issues.
- de Amy Geeter
He has now taken the EGR valve off (which is black inside), and the inside of the intake is black as well.
- de Amy Geeter
A car needs 4 things to run: Air, fuel, spark and compression. If any one of these are missing the car won't run well or at all. My suggestion would be to check the spark plugs to make sure they are sparking. This can be done by removing the spark plug, contacting it to a metal engine component and turning the engine over briefly (Do not let it run for any extended period of time like this). Be sure to wear some nice thick gloves so you don't get shocked. Fuel should also spray out of the hole that the spark plug was in. Check all your cylinders and be sure each one is getting fuel and spark. Let us know what you find.
- de Phillip Takahashi
Mostrar 8 comentarios más
