Saltar al contenido principal
7th generation of Motorola's Moto G line. This phone was released in March 2019 and is the first Motorola Moto to use the Android 9 operating system. Model numbers are XT1962-1, XT1962-4, and XT1962-5.
Preguntas 17 Ver todo
Re-solder/replace power connector with cold solder joint?
USB port/power connector moves up and down when I attach the power adapter and can no longer make a connection no matter what cable I use, so I suspect a cold solder joint, likely from the phone being dropped too many times with the cord attached. If that's what it is, I've re-soldered electronics (not phones) in the past to fix this, but I'm wondering: (1) Is that likely what it is or could something else be loose on the G7? (2) Has anybody ever fixed this issue? (3) How difficult would this be?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
the pins of the port have probably disconnected from the board, could have potentially ripped solder pads aswell
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Mark Schultz estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 32
