Saltar al contenido principal
La revisión de 2016 de Apple a su línea de computadoras portátiles dirigida a usuarios profesionales. Cuenta con una pantalla Retina de 15 pulgadas, 2880 por 1800, Intel Core i7 de cuatro núcleos, opciones de almacenamiento de 256 GB / 512 GB / 1 TB / 2TB, 16 GB de RAM y un teclado equipado con una barra táctil. Lanzado en noviembre de 2016. Características del modelo A1707.
Preguntas 259 Ver todo
Won't sleep when lid is closed
Hi everyone,
When the lid is closed on this MacBook, the laptop doesn't go into sleep mode. This happens whether it is plugged into the charger or not. macOS has been clean installed and that has not helped.
I believe that it is very unlikely to be software related at all, so I would like to know what parts of the MacBook can cause this. I assume there is some sort of H.A.L.L effect sensor in the top case, but would replacing the top case resolve this issue? (the battery needs to be replaced too so it isn't too bad to do this at the same time.
Thanks, Philip
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Yes your system uses a Hall sensor with a magnet imbedded in the displays lid. The Hall sensor is hidden in the Right side speaker MacBook Pro 15" Retina (Late 2016-2017) Right Speaker
Replacing it should resolve things. But to be sure use a rare earth magnet sliding it along the face area of the speaker area the display should react if not that’s your problem.
Imagen de MacBook Pro 15" Retina (Late 2016-2017) Right Speaker
Producto
$24.99
Fue útil esta respuesta?
Puntuación 1
1 comentario:
thank you. will check that out.
- de
Añadir tu respuesta
Philip Race estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 46
