Saltar al contenido principal
Modelo A1312 / Mediados de 2011 / Procesador Core i5 de 2.7 & 3.1 GHz o Core i7 de 3.4 GHz
Preguntas 687 Ver todo
GPU Still not working after buying new one for iMac
Hi i recently just got a new gpu for this iMac i am trying to repair and the iMac is still not showing a display. diagnostic led #3 is still of (this LED indicated if the iMac is communicating with the GPU).I don't know if i installed it correctly or something like that but if someone could help that would be great. the iMac does do a boot up chime so the motherboard and psu is still working.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Are you able to enter into Target Disk Mode by using the startup T key once you restart your system.
If you get a display image you’ve proved the display is working, but the GPU board is not the correct one. This test uses the Intel CPUs graphics engine. If you are not getting an image the logic boards displays LVDS connector is not making connection to the cable or the cable is damaged.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Yo, i think i got a incompatible or got sold a faulty gpu, have returned and im going to get another one that im certain is compatible. i will keep you updated, and thanks for the answer Dan. ( :
- de
Añadir tu respuesta
Bentley100 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 32
