How to check for continuity in power button?
As title says I want to check for continuity but am not sure how.
Es esta una buena pregunta?
The best way to isolate if the button is not working is to use the power pads Using MacBook Pro 2013 2014 2015 power pads if the system responds then the keyboard switch is damaged and you likely need a new keyboard assembly.
Here’s a deep dive into how the button works Macbook Pro Retina bad power button but every other key works!
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 40
What are you encountering now? A bit more info would help.
- de Dan
Power button doesn’t work, replaced trackpad fully thinking that was the issue it wasn’t.
- de asdas sdasdsa
