Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Teléfono Android de Huawei, lanzado en diciembre de 2014.
Scratched battery foil during removal
I scratched my phone battery foil as I was tryi6to remove. After fixing the phone and fixed back the battery, turn on the phone. The battery started draining fast. How do I fix the battery to hold char
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
@samken "How do I fix the battery to hold char" you do not. You replace it. It is absolutely possible that you have received a bad battery. Replace it once more from a different seller and re-evaluate. You also want to make sure that you have your power saving mode on, and your apps and network settings reflect those as well.
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
Ok thanks, I will have to replace it then with a new battery
- de
@samken It's the safest thing to do. Best of luck.
- de
Añadir tu respuesta
Samuel estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 331
