Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Panasonic Lumix DMC-G7 es una cámara de lentes intercambiables sin espejo de nivel de entrada lanzada en mayo de 2015. La cámara tiene una resolución de 16MP y es capaz de capturar video 4K. Los números de modelo son DMC-G7 en la mayor parte del mundo y DMC-G70 en Europa.
Menü and other back buttons doesn't work.
Hello, i buyed the camera used and it got one time opened and the screen cable was not good so I replaced it and it's working now but all back buttons doesn't work.
I can't enter the menu or other things nothing happens. The connector and the flex cable looks good tried 5 times to put in and out the cable but nothing happens.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
It's possible that the issue with the camera's back buttons not working is due to a problem with the circuit board or a software issue. If the connector and flex cable are both in good condition and properly connected, then it's likely that the problem is not with the cable.
One solution you could try is performing a factory reset on the camera to see if this resolves the issue. If not, then it may be necessary to take the camera to a professional repair service to diagnose and fix the problem.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Andreas S. estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 550
