Saltar al contenido principal
Dispositivo disponible en tiendas desde el 22 de septiembre de 2017. Modelos: A1863, A1905. Disponible como GSM o CDMA / 64 o 256 GB / Colores - oro, plata o gris espacial.
Preguntas 824 Ver todo
Epoxy over SMDs on iPhone 8 logic board?
Here's a stitched image of the area just to the north of the battery connector on my mainboard. (The phone's on the bench turned sideways with the charge port to the right. Click on the image to get a better view. Sorry for the poor contrast. Black components, foam and goo on a nearly black board. The only thing that really stands out are the gold contacts.)
My iP8 mainboard developed charge control problems after replacing the charging port assembly. I was running thru the list of causes of charging problems, first looking to see if I had accidentally knocked off one of the SMDs near the battery connector with an errant fingernail.
When I got in there with a microscope I was surprised by what I found. You can see the edge of the battery connector at the bottom of the photo and a mosfet at the top slightly to the right of center. In between that mosfet and the test point at the center of the image, there should be another mosfet package, one that is often knocked loose by accident. But on my board there's this weird black crud covering the area and extending horizontally, covering many other smaller SMDs near the connector as well.
In the image it looks like goo, but in fact it's a very hard substance, like ceramic or epoxy. I assume this was done during manufacturing to prevent accidental damage when connectors are being mated/unmated. Has anyone encountered this before? I haven't seen anyone else mention it on this forum or on other phone repair sites. I'm hoping someone can confirm my guess -- that the second mosfet and other SMDs are there under a layer of epoxy -- or give a alternate explanation. Thanks!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
That is overfill. A substance used to protect components on the board. If you look it's all over the board. To remove it you need to heat it up and gently scrape it off without damaging the board or anything else.
Fue útil esta respuesta?
Puntuación 4
1 comentario:
Thanks! I was guessing it was something like that. But I googled "overfill SMD protect components" and didn't come up with anything. I was hoping to read more about it, and see some images. If you have any good links on the topic or know of better search terms please share.
- de
Añadir tu respuesta
Robert Miller estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 29
