Saltar al contenido principal
Descubra información de reparación que incluye guías y consejos para frigoríficos Whirlpool. Nuestros completos recursos ofrecen instrucciones detalladas para solucionar problemas y reparar problemas comunes en varios modelos de frigoríficos Whirlpool.
Preguntas 95 Ver todo
Why does my ice maker and water dispenser work with filter removed but
Why does water dispenser and ice maker work when filter removed but doesn’t when filter installed
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @thomasmo
A lot of refrigerators have an automatic filter bypass mechanism in the filter housing (example only) which activates when the filter is removed so that water is still supplied to the ice maker and the water dispenser.
When a filter is inserted it should cause the bypass mechanism to switch the water supply back so that it now goes through the filter. Make sure that the filter is fully inserted and locked into place
It may be that the housing (incl. the bypass) is faulty. Here's a video that shows how to replace it.
What is the model number of the refrigerator? Knowing the model number of the refrigerator will ensure that you can find the correct one for your model.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Art Morris estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 21
Ultimos 30 días: 93
Todo El Tiempo: 2,375
