Saltar al contenido principal
El iPhone 2021 estándar de Apple se lanzó el 24 de septiembre y viene con una pantalla OLED de 6.1", un sistema de cámara dual de 12 MP y en cinco colores disponibles. Sucesor del iPhone 12.
Preguntas 85 Ver todo
I can’t hear phone calls unless iPhone is on speakerphone how to fix?
iphone13 can only hear phone calls on speaker or other audio device. I have run through a lot of suggestions online. Going to reset to factory defaults. I’m concerned it is a hardware issue. How do I trouble shoot solutions before taking it to shop or opening phone up?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
I would have a look at the iPhone No Sound troubleshooting page. But chances are there is an issue with the receiver speaker (earpiece speaker).
I would see if you can isolate which functions work properly. Try and play some media and set the balance entirely to one side or the other and see if that effects the sounds. That speaker will also function as an amplified speaker for playing media in stereo. It may just be the speaker grills are all gunked up.
The receiver speaker (or top speaker as Apple calls it) on these is no longer attached to the display, and if I recall correctly it takes some doing to get at if that turns out to be the issue. I believe the logic board has to come out to remove it.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Joseph Lopez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 117
Todo El Tiempo: 4,960
