Saltar al contenido principal
Segunda generación de iPhone. Modelo A1241 / 8 o 16 GB de capacidad / plástico negro o blanco de nuevo. La reparación es más sencilla que el primer iPhone. Requiere destornilladores, curvas y herramientas de succión.
Preguntas 1511 Ver todo
dropped in water, what to do?
dropped i phone in water, had protective case on. Seems to be OK except that when I place a call and receive a call I cannot hear anything, the mute is NOT on. Have it turned off and siting in a bag of rice. thoughts????
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
3 Respuestas
Respuesta Más Útil
DONT TURN IT ON FOR A FEW DAYS. leave it in the bag of rice and power it back on in a few days. If you still have problems you might need to replace the speaker assembly. Search this forum for "water damage" or "liquid spill", you'll find dozens of threads with helpful ideas.
Fue útil esta respuesta?
Puntuación 3
It is important to not turn on electronics after it has touched water. However if you want a different item than rice to tuck your electronics in you can try the Thirsty Bag.
Puntuación 1
Before you do anything insure that the device is completely powered down!
Go to the grocery store and buy the zip lock bags for the freezer that you can vacuum the air out(it works with water too). Place your iPhone or other electronic device inside and add rice too(it will capture the water as it is drawn out of the device). Now close the bag and start using the vacuum. Go back periodically and use the vacuum more. Two or three days later remove the device from the bag and gently warm the device(no more than 100 degrees). After a day of that you device should work. If not sell it to a repair shop and buy another one.
Puntuación 1
Añadir tu respuesta
Amy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 3,621
