Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Valve Index Base Station es un dispositivo que se utiliza para rastrear la posición de los cascos y controladores de realidad virtual. Utiliza tecnología infrarroja para rastrear con precisión la ubicación del equipo de realidad virtual en una habitación, lo que permite una experiencia de realidad virtual más inmersiva y receptiva.
What type of connector is used for the base station power cable?
The cable going between the wall wort and the base station had the connector snap in the wall wort. It's a small two prong adapter with a plastic flange that seems like it'd be relatively simple to re-solder if I could find a spare, but I have no idea how to find it. A name or a purchase link would be fantastic. To be clear I am referring to the plug on the other end of the cable from the barrel plug. I believe it is some kind of molex connector?
Female:
Male (this is the part I need to replace):
Es esta una buena pregunta?
Puntuación 0
2 comentarios
A pic would be super helpful
- de
Updated with photos. I've done some more digging and I think it might be a molex micro-connect
- de
Agregar un comentario
1 Respuesta
Solución Elegida
This is most likely a molex connector, as you have pointed out.
As far as I can tell, this should be part number 436450200 which you can view and also get a 3D model of on their official website.
Fue útil esta respuesta?
Puntuación 3
1 comentario:
PS: Had the same issue on mine. I feel like this was a very bad design choice...
- de
Añadir tu respuesta
Walter Gray (Shenanigans) estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 43
Todo El Tiempo: 1,109
