The little black "DO NOT REMOVE" sticker
Does the little black "DO NOT REMOVE" sticker in the bottom right of the iPhone 3G serve any other purpose?
Es esta una buena pregunta?
Segunda generación de iPhone. Modelo A1241 / 8 o 16 GB de capacidad / plástico negro o blanco de nuevo. La reparación es más sencilla que el primer iPhone. Requiere destornilladores, curvas y herramientas de succión.
Nope, just a warranty sticker.
Besides telling you not to remove it? No, as Chris Green says, once you remove it, your warranty is invalidated.
Rep: 1
It's on top of the antenna wire. if you mess with it you can damage your iphone's signal or worse reflects no service.
Comentarios:
Where did you find that information? So by removing the sticker I decrease the signal ;-)?
- de oldturkey03
no.. it's on top of a screw that holds the motherboard in contact with the battery connection. I think your antenna problem is damage elsewhere on that little wing of the motherboard.. it is easy to try to force the motherboard out and the gold prong to the antenna is damaged..
- de pollytintop
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 59
Todo El Tiempo: 11,647
