Saltar al contenido principal
Lanzado en abril de 2010 / 2.4, procesadores Core i7 de 2.53 GHz o procesadores Core i7 de 2.66 GHz
Preguntas 591 Ver todo
2010 MacBook Pro does not chime and has no display on startup.
I was using my laptop as normally a few days ago. I had the display at low brightness and the volume turned off (not sure if this has something to do with it).
I let the computer run out of battery. When I charged it overnight, the indicator on the side said it was full but when I went to power it on, nothing showed on the display and I could not hear a chime. I did hear the fans spin and the disk drive made a noise but that was it.
I also have the disk partitioned so sometimes when it restarts it boots into a blank screen that says something like "no bootable drive found" but normally I can avoid that by pressing option and selecting my drive. Is there a common fix for this?
I have tried plugging it into an external display but there was no output. I have also let it run out completely from the fans spinning and charged it again, but it still has not made a difference.
I did change the battery, but that was in September and it has been working fine since then.
Fix: I left my computer alone for a week or so and I tried resetting the pram. I pressed the power button while hold command option p and r and I heard the chimes. After the display booted back on, I realized it was booting into my second partition of windows, which is extremely glitchy. Once I tried to boot it into mac, it worked fine.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Let’s give this a try, disconnect the battery following this guide Reemplazo de la batería de MacBook Pro 15" Unibody mediados 2010 stopping at Step 4. Then with nothing connected press and hold the power button for a good 15 secs. Carefully reconnect the battery and try starting the system again. Did that work?
Update (12/26/2022)
Sadly, this looks like something deeper in the logic board.
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
I will try it after Christmas, thanks.
- de
Hi @danj I tried what you suggested but the issue is still there. When I press the power button, the light on the front of the computer turns on, but turns off again once I release it. Could it be the gpu or another large issue or could it be software related?
- de
Añadir tu respuesta
SamuraiSammy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 131
