Why won't Power Mac G4 MDD power-up without cycling ac power?
Pushing the power-on button won't start the computer, as it should, unless the ac power is cycled first. What's the cause and what's the fix?
Es esta una buena pregunta?
Some things to try - press the PMU reset button, check/replace the PRAM battery, check PSU
Fue útil esta respuesta?
The PRAM battery looks to be in this GUIDE - step 5
I did (prior) replace the "clock battery". Is that the PRAM battery? I did not try the PMU reset button.
Yes - the PRAM battery also powers the RTC (real time clock) so if that is flat the date/time will be wrong
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 936
