Saltar al contenido principal
The seventh-generation Golf had its début in late 2012 at the Paris Motor Show.
Preguntas 9 Ver todo
Po2800 car is wasting gas
Why does car have po2800
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Is this supposed to be an OBD-II trouble code? P2800 is a code for the transmission range sensor, or PRNDL selector being out of range, if that's what you're talking about.
What do you mean by wasting gas? Your gas mileage has dropped significantly; is that what you mean? If you're actually getting a P2800 code, it could be that the transmission has been set to a low gear so when you're at highway speeds you're revving the engine like mad, but that should be pretty noticeable.
You'll need to clarify your question if you want a real answer.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
angel torres estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 317
