Saltar al contenido principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Preguntas 1469 Ver todo
Computer not recieving power from battery, Magsafe lights not on
I have been dealing with this problem for sometime now. I have a 2007 macbook, that wont power on. The last few days it has only functioned while plugged in. Today the magsafe lights don't turn on and the battery still has a charge, but the computer wont power on. A similar experience happened several months ago, the computer would not charge for several weeks, and then i plugged it in again one day and it just randomly charged again, and has worked fine since then. Any help you can give me would be great.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Comentarios:
Apple MacBook "Core 2 Duo" 2.0 13" (White/07) Specs
Identifiers: Mid-2007 - MB061LL/A - MacBook2,1 - A1181 - 2139
por
Agregar un comentario
Kits de Reparación de Batería de MacBook Air
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
1 Respuesta
Solución Elegida
Use a multimeter to test out the Magsafe adapter. Here's the pinout on the right side of the page. It could also be your DC-IN port or a combination of the two. So test the adapter first. Press the button on your battery to see if it has a charge, you could have battery problems or battery connector issues. Next remove the batter and adapter, press and hold the power button for 5 seconds, reattach the adapter and give it a try. Let us know your results and we can go from there.
Fue útil esta respuesta?
Calificación 3
Comentarios:
Battery has a charge, and i checked the adapter and its working fine. I plugged it in today, and now it is receiving power (Magsafe light on and computer powered up) but i still can't use it with out it being plugged into the adapter. Any thoughts?
por
Also the battery is only charging up to 1 light out of 5 (when you press the button on the battery) and then it says the charge is complete.
por
Download and run Coconut Battery to find the condition of your battery and how much charge it should be able to take. http://www.coconut-flavour.com/
por
BATTERY CHARGE
Current charge: 51712 mAh
Maximum charge: 51915 mAh
BATTERY CAPACITY
Current capacity: 51915 mAh
Design capacity: 5200 mAh
DETAILS
Mac model: MacBook2,1
Age of your Mac: 54 Months
Battery load cycles: 339
Battery Temperature: 30.2 degrees Celsius
Battery power usage: 0.0 Watt
por
Somethings not right here. Your showing the battery at 10 times its capacity and didn't state if it was charging or not.
por
Mostrar 4 comentarios más
Añadir tu respuesta
Jason Longhurst estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 629
