Saltar al contenido principal
An update to HTC's original Vive, now with improved displays, sensors, and ergonomics. Released April 5, 2018.
Preguntas 26 Ver todo
Will your Vive Pro Headphone replacement part fit the Vive Pro2?
Hi, I have a Vive Pro 2 Headset and the left earphone is failing [sound stops playing on the left side]. Will your replacement part [Item # IF453-028-1 HTC Vive Pro Headphones] fit the Vive Pro 2 headset?
I have already removed the left earphone and verified that the contacts are clean. The sound is intermittent. I need a replacement part for the left earphone that has the volume control button.
Has anyone successfully used these replacement headphones on a Vive Pro 2 Headset?
Thank you,
Edward
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Hey, Edward.
As long as you're capable of doing it yourself, I'd say it's fine to use a Vive Pro Headphone replacement on the Vive Pro-2. There is not too much differentiation between the two headphone parts, and certainly not enough difference to cause an issue. I hope you find this helpful.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Edward Leslie estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 26
