Saltar al contenido principal
Información de reparación y desmontaje para el iPhone SE de segunda generación, anunciado y lanzado en abril de 2020.
Preguntas 20 Ver todo
Battery is charging but doesn't indicate charging
Recently I changed the housing of my phone and a problem occurred. When the phone is off, if I connect it with the charger, it turns on but it doesn't indicate that is charging and the battery level is slowly reducing which would be normal if the cable was not connected. If I leave it some hours with the charging cable on then the battery level will go to 100%
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi Alan,
Assuming it was all working before the housing swap, we'll rule out the motherboard as the source of the problem to start with. That leaves us with two prime suspects, the lighting port assembly and the battery.
With regard to the battery, it's always possible that it got damaged in the process of removing it and relocating it to the new housing. That isn't my first inclination, though; I'm a little more suspicious of the lightning port flex assembly, myself.
Did your new housing come with that part, or did you pull the old one and install it in the new housing? Either way it's possible it's at fault; I know when I did a housing swap on my grandson's iPhone X, it turned out the charging port assembly had a bad sensor on it and I ended up having to replace it. Contrariwise, if you used the old one, it could be that it got damaged in the process and is now giving you problems.
If it was my phone, I think that's where I'd start, first with double-checking all of the lighting port and battery connections and examining the connectors themselves with a magnifying glass, then cleaning them with 90% or higher isopropyl alcohol and check to see if it made any difference.
If not, I'd probably go ahead and replace the lightning port assembly and if that didn't do it I'd go with a new battery.
These are just my thoughts; take this advice for what you paid for it. Hopefully some of the members here who are actual repair technicians can chime in and add their opinions.
Good luck; let us know how it goes!
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Thank you. I was thinking doing the same thing but first I will check if anything is wrong with the software
- de
Añadir tu respuesta
Alan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 52
