When my ceiling fan rotates the noise is like type writer
When my ceiling fan rotates the noise is like type writer hitting sound . What could be the problem?
Es esta una buena pregunta?
Hi Sethuraman,
I just went through this at my son's house; all of his ceiling fans were noisy in different ways; on two of them the blades were loose and just had to be tightened; the other one wasn't mounted well to the ceiling and had to be resecured.
So yeah, grab a Phillips screwdriver and tighten all the screws that hold the fan blades onto the motor. I'd almost be willing to bet that will take care of your noise.
Good luck; let us know how it goes!
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 28
Hi,
Does it also make the noise if you rotate the fan blades manually i.e. not by using the power?
Are any of the blades loose at all?
- de jayeff
