Saltar al contenido principal
Lanzado el 4 de noviembre de 2017. Modelo A1865, A1901. Disponible como GSM o CDMA / 64 o 256 GB / Silver o Space Gray. (Se pronuncia igual que "iPhone 10.")
Preguntas 1198 Ver todo
PLEASE HELP!Attempting to fix my screen, lifting to inside of screen.
My screen got a crack in it. So I decided to replace it. When lifting the screen to get into the phone, instead of lifting ALL of it up, it is just lifting the display itself up... I don't want to be on the inside of the screen, rather the inside of the phone. PLEASE HELP!!!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Okay Joseph, calm down, it's okay.
First off, usually the reason the LCD separates from its frame is that you neglected to take out the Pentalobe screws securing the frame to the case. You did take them out, right? If not, do that now, before anything else.
Now, assuming you've got the LCD mostly off, you've got two choices. You can finish the job (you're replacing it anyway, right?) then tackle the frame that's still on the phone, or you can go back around the phone and make sure you're under the frame this time and free it all up that way.
This is what your phone will look like if you take the LCD off without the frame.
Versus the inside without the display frame.
You're not the first to run into this; here's another post from someone who had the exact same thing happen.
SOLVED: Why does the inside of my iPhone x look different than everyone elses? - iPhone X - iFixit
You'll be fine once you have the frame and the LCD off; nothing you're doing will damage the rest of the phone, only the old LCD that you're replacing anyway.
Let us know how it goes.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Joesph Dunne estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 231
