Saltar al contenido principal
Repair guides and support for motherboards and CPUs.
Preguntas 145 Ver todo
CPU light is on on motherboard, display goes out.
On my desktop computer, the CPU light on the motherboard is often on and there is no display on the screen.While the fans keep spinning, it doesn't get fixed unless I reset it.I searched and took it to repair, they couldn't find the problem, I would be glad if you could help.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
7 comentarios
https://www.asus.com/us/support/FAQ/1042...
problems Ur CPU one of the pins are broken most likely
- de
or improper installed
- de
Normally there is no problem, sometimes it happens.
- de
@fatihsir what model is your motherboard? what model is your power supply?
- de
Msı b-450m pro-vdh plus
- de
Mostrar 2 comentarios más
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@fatihsir check your PSU. It is possible that you are losing power to the CPU which would/could cause this to be recognized as a failed processor
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Fatih Dogan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 75
