Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Un PC de escritorio construido a partir de piezas de bricolaje listas para usar, en lugar de uno prefabricado de un fabricante importante. Estos también pueden ser construidos por un IS utilizando piezas listas para usar.
New psu not workin
Hi, i recently upgraded to a 3060ti and with that a New psu but with it my pc is not turning on, whenI try with my old psu my pc still works fine but not with the New one, i have tried reseating the cables many times but no succes, when i plug the New psu into the wall my gpu/psu fans start for a brief moment and then stop again and pc wont turn on, any help?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
14 comentarios
@finiego what are the make and model of your old PSU and same for your new PSU?
- de
@finiego @oldturkey03 was asking what the make and model is of both your old, and your new PSU
- de
@geirandersen thanks brother :-)
- de
@oldturkey03 oh sorry, the old one is FSP group Inc and the New one T.F.skywindintl both server psus, because my case is small
- de
Mostrar 9 comentarios más
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@finiego I’d seriously suggest getting a multimeter(maybe borrow one from a friend). It must be able to measure DC voltage (just about every digital multimeter does). Connect the old PSU to power (doesn’t have to be in the PC) and measure each pin. You need to find one GND and put the black probe on that. Then go over every pin and check with the red probe. That should read either 12V, 5V or 3.3V (only on the new PSU!). Write it down, I like to draw a picture of each plug and write voltages on each pin, with arrows.
The do the same on the new PSU. Once complete, compare the readings and see if everything corresponds.
The old PSU only had 12V and 5V, while the new one also has 3.3V
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Fin Faas estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 16
Ultimos 30 días: 56
Todo El Tiempo: 396
