Black Conductive Pad under battery inside rear panel?
Where can you get these one side adhesive conductive copper / aluminium pads or tapes, do you know where ?
Es esta una buena pregunta?
The copper helps dissipate heat, like a heatsink. When I work on iPod's, for example the touch 4g, I also add a dab of arctic silver paste since the paste is usually dried up.
You can find adhesive backed copper sheets, just cut to fit, google :
copper foil sheet
Fue útil esta respuesta?
Thanks
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 284
7 comentarios
Is this a necessary component?
- de Brad
I think so, because when the battery charges, it heats up. The pad takes the heat and via the body transfers it out of the case.....
- de Arnoud
do you mean on back of motherboard or on inside of rear case???
- de pollytintop
Inside of rear case behind battery....
- de Arnoud
Slide 30 in changing the rear case gives a good view.
- de Arnoud
Mostrar 2 comentarios más
