I replaced my dead USB charging port but it still doesn't work.
Hi, i just recently replaced my broken USB port for my 6-year-old DS4 controller, I requested a JSD-30 to replace the current one which as another JSD-30. Everything went smoothly until I tried to plug my controller directly to my PC, it doesn't recognize it, and it doesn't connect to the DS4 through the USB cable (to clarify, I don't use it on the PS4 anymore since I gave my PS4 to my mum to watch Netflix on her spare time). I took the DS4 apart again, and it shows a very dim blue light, it can only be seen when I take the controller apart or a very low light environment.
Es esta una buena pregunta?
Have you checked your soldering to see there are no bridges between the pins? Nudge each pin gently from the side to make sure they're soldered properly. If it moves it'll need redone. Sounds like there's an issue with the soldering somewhere. That or a blown component on the board
- de [deleted]
