Saltar al contenido principal
Modelo A1312 / Mediados de 2011 / Procesador Core i5 de 2.7 & 3.1 GHz o Core i7 de 3.4 GHz
Preguntas 687 Ver todo
Is there a tutorial for the logic board replacement?
Is there a guide out there on how to replace the logic board?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
@civil35 this guide IMac Disassembly should work for you. To remove the logic board you do not have to follow all the steps just remove:
• Glass panel
• LCD panel
• Power supply
• AirPort card
• Backlight pressure wall
• Optical drive
• Optical fan
• IR board
• Memory
Note: The SSD-only CTO option has a hard drive power plug, on the back of the logic board. It shorts out the HDD power when no HDD is present. Transfer this plug (922-9877) if replacing the logic board.
This is a comment only since the snippet of the disassembly needs to be verified by you. Let us know if this worked for you .
- de
Agregar un comentario
1 Respuesta
iMac Intel 27" EMC 2429 Motherboard Replacement
This is the closest I can find. This guide is still in progress, so be careful.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
John Myers estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 34
