Saltar al contenido principal
Información de reparación para el iPod shuffle de cuarta generación. Lanzado en septiembre de 2010. Número de modelo: A1373.
Preguntas 29 Ver todo
iPod won't turn on or won't charge
It was still in the package when I bought it. I can plug it into my computer, fine. The orange lighting blinks like it's charging, and itunes syncs with it fine, and itunes says theirs mp3s on it loaded fine. I have the latest version on it. I left it plugged in to charge overnight. I have tried restoring it.
But when I unplug it from my computer and flip the switch to shuffle or continuous, nothing happens. No audio and the battery indicator light doesn't even turn on.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi
Due to the iPods age it is most likely a bad battery
Battery’s degrade with age even if they are left sitting unused,heat can also affect a battery’s life span
Heres a guide showing you how to replace your battery
iPod Shuffle, reemplazo de batería de 4ta generación
It is a soldering job just so you will need a soldering iron ,solder ,flux and a solder wick to do it
Hopefully this helps
Any questions please ask
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Thanks for this. I was afraid that may be the case. I don't have access or knowledge on soldering. I waisted $79 :(
- de
@allura.morneau
I’m sorry to hear that
If you ordered it on eBay you could try and return it and get your money back
Or if you wanted I could show you step by step how to desolder the battery and put a new one in
It’s not too hard and soldering irons aren’t too expensive
Entirely up to you, no pressure just do what you feel is best:-)
- de
Añadir tu respuesta
allura.morneau estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 38
Todo El Tiempo: 266
