Saltar al contenido principal
La revisión de 2016 de Apple a su línea de computadoras portátiles dirigida a usuarios profesionales. Cuenta con una pantalla Retina de 15 pulgadas, 2880 por 1800, Intel Core i7 de cuatro núcleos, opciones de almacenamiento de 256 GB / 512 GB / 1 TB / 2TB, 16 GB de RAM y un teclado equipado con una barra táctil. Lanzado en noviembre de 2016. Características del modelo A1707.
Preguntas 260 Ver todo
2016 MacBook Pro retina touchbar dead
I have a 2015 MacBook Pro Retina with touch bar. One day I noticed the battery was not at 100%, even though the computer was plugged in. The battery slowly discharged down to zero and now it won't turn on, it only makes the dead battery symbol on the screen. I have tried another charger and it makes no difference. I also removed the bottom case and disconnected the keyboad and trackpad cable and it made no difference. I also tried all the keyboard reset key patterns. It seems like parts of the board get hot when the power cable is plugged in, but still won't power on. The fans would turn on for a few moments when I try to turn it on but that's all.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
4 comentarios
Did you try using a different charging cable? Perhaps the one you have doesn't work anymore
- de
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Agregar imágenes a una pregunta existente
- de
It was completely and totally dead as a door nail. Now it turns on but shows a folder with a question mark, which apparently means it cannot find an operating system. I plugged in a bootable ubuntu usb stick and it will boot up on that. I cannot find any sign of the original main drive when playing around in Linux. There is a slight burning smell, perhaps the ssd is fried.
- de
@Erik Mueller - Well, first of all your Ubuntu boot dive won't let you see the Apple propriety APFS volume so that makes sense!
What you need to do is restart your system and press the Option (⌥) key to see if you can see the boot drive
Reference: Mac startup key combinations
Use the arrow keys to select the volume did it startup?
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Unplugging the trackpad and keyboard is a good start, but my approach to no power issues is usually as follows.
Take off the bottom case. Disconnect the battery—both the little cable AND the T5 screw (which is actually what transmits the power to the board). Disconnect everything other than what is strictly necessary for the machine to boot up and have display. So basically leave one of the two USB C boards connected. And the display. Leave battery disconnected and use the charger to get it to boot. See if you get power at that point. If so, reconnect stuff until you no longer get power. Make sure to try both USB C board. It could also just be a bunk battery.
If you still don’t get power at that point, try reconnecting keyboard and/or trackpad, but disconnecting the display to see if that’s the issue. Keyboard will facilitate fan connection to the board so you could tell if it’s getting power that way. Or trackpad would give you haptic feedback, which is usually a good indicator that it’s booting if that’s clicking consistently.
If still no power at that point, more than likely its a board issue. It’s possible it’s still repairable even if that’s the case, just will be trickier.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Erik Mueller estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 225
