Saltar al contenido principal
Procesador Intel de doble núcleo modelo A1502 / 2.4, 2.6 o 2.8 GHz / Lanzado en octubre de 2013
Preguntas 552 Ver todo
Is there a way to revive a MacBook battery?
Hi guys,
About a year ago, I purchased a MacBook battery (according to Coconut Battery, it could actually be an original battery manufactured in 2014, by Simplo).
It worked fine at the beginning. But after a while, it wouldn't charge to 100%, and now it looks like it's completely dead, with 83% left on it. It doesn't charge and it doesn't discharge. If you unplug the charger, the laptop shuts down.
So the question is: is there a way to revive a battery? In this case, a MacBook battery?
Is the only solution here replacing the battery (again)? If so, would you recommend going for another potentially original battery (considering they're already very, very old) or purchasing a newer, but likely not original battery? Do you know any third party good battery manufacturers for this model?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Hi
There is a way that could work but it can be extremely dangerous and isn’t recommended
If you connect it up correctly to a bench power supply and you charge it slowly it could bring it back but it isn’t recommended as playing with lithium battery’s and electricity is very dangerous
So I would just recommend buying a new battery or getting a new one under warranty if it’s still under it
Also I would have a look at this link
https://www.batterypoweronline.com/news/...
That @danj kindly mentioned as it’s very interesting and can give you a better look into what happens inside a battery
Hopefully this helps
Any questions please ask
Fue útil esta respuesta?
Puntuación 2
5 comentarios:
Conveniently enough, the battery I got had a 1 year warranty. I guess it lasted exactly that long. :))
Anyway, thank you very much for the advice! :)
- de
@arsradu
Your most welcome:-)
Maybe considering trying to claim the warranty as some places will accept a little after the warranty ends
No guarantees though!
- de
@hellomacos - I would point out the chemistry of the battery and its construction often negate recovery. And in truth all you're doing is burning out the Lithium dendrites but once the pathway is present a new dendrite will follow its pathway! So you only typically gain a few cycles.
Sadly, it also weakens the battery so it is likely to fail and it could fail rapidly! Risk of blistering of the cell and fire/smoke!
- de
@danj
Thanks for the feedback
It’s greatly appreciated
Il have a look into the link you sent me
Once again your feedback is greatly appreciated
- de
@danj
Just had a look!
It’s very very interesting how these lithium dendrites behave and can cause your battery to eventually fail
Il mention it in my answer
Thanks again:-)
- de
Añadir tu respuesta
arsradu estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 68
Todo El Tiempo: 912
