Saltar al contenido principal
Modelo A1174 con 2 GHz Core Duo o Modelo A1207 con 2,16 o 2,33 GHz Core 2 Duo
Preguntas 212 Ver todo
replace PATA optical drive with an SSD drive
last night I had a crazy idea!
would it be possible to replace optical drive (PATA)
with an SSD drive?
the only problem is the PATA connection instead of SATA, I don't know if there is an adapter or PATA SSDs
edit: I found this:
[ http://eshop.macsales.com/item/OWC/SSDMX...|OWC Mercury EXTREME Pro Legacy Edition 9.5mm for IDE/ATA desktop systems]
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Solución Elegida
Here's what you need to put in a SATA hard drive in your PATA optical bay slot: [producto vinculado inexistente o deshabilitado: IF107-078-1]
Fue útil esta respuesta?
Puntuación 5
4 comentarios:
from the notes on the link: This enclosure does not work with ATA drives or hard drives thicker than 9.5 mm.
plus: Compatibility >> MacBooks
- de
Try this one: [producto vinculado inexistente o deshabilitado: IF107-079-1]
- de
again on the notes: This enclosure does not work with ATA drives or drives taller than 9.5mm.
which I don't understand why! PATA drives have different sizes?
- de
ok finally I can answer to my own question!
this a Caddy for this type of iMac. It converts Sata (internal) to Pata (external) you can use any data connection 2,5" drive (ssd or hdd).
here is the site selling it:
http://www.newmodeus.com/shop/index.php?...
Puntuación 1
Añadir tu respuesta
joleisa estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 3,805
