Saltar al contenido principal
Repair guides and support for your LG TV.
Preguntas 1140 Ver todo
LG 55eg910t broken display
Vertical lines appear on the left side of the screen and the rest of the screen is blank when powering it on. What could possibly be the problem? The main board? The TV is already broken when I bought it on purpose to fix it.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
@notatechfixer let us see what your screen displays. Agregar imágenes a una pregunta existente
If it is a broken display, then it gets expensive, if even possible. Screens that size are extremely hard to come up and if you do, they cost more than a new TV. You can always check by looking on the label on the inside, glued to the metal cover for the LCD panel. TRy an online search to see if you can find the scree. Anything else can usually be repaired with something as simple as a board replacement or bad wires. Again, for that we would have to see what it looks like.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Lance Ivan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 27
